Quick question about mopar lip kit.
Old Oct 11, 2007 | 10:43 PM
technical18's Avatar
technical18
Default Quick question about mopar lip kit.
I just got a set of blaze red side skirts in. Do i need to sand them down and completely remove the red, or will just scuffing the clear coat off be sufficient to get them ready to be painted?
Old Oct 12, 2007 | 07:58 AM
technical18
Default RE: Quick question about mopar lip kit.
anyone?
Old Oct 12, 2007 | 10:11 AM
spikeymikey87's Avatar
spikeymikey87
scuff the clear coat with a high grit sandpaper
Old Oct 12, 2007 | 10:19 AM
ricerchik02's Avatar
ricerchik02
I use a sanding sponge from Autozone. Those things are awesome! They have labels on them too besides the grit number that shows what to use it for. They have one for paint stripping, paint surface prep and finishing or something like that. You can use them wet or dry and they last a long time.
Old Oct 12, 2007 | 11:24 AM
Adionik's Avatar
Adionik
Okay, I ordered the same color side skirts you did and painted them solar yellow.
It was a BITCH. the paint kept reacting with EVERYTHING! the primer wouldn't take to it. We sanded all the clear off of the red, almost even to the plastic at some points.
We had to use a flex primer....damn that red **** they used was horrible. Just be prepared if stuff goes wrong.
Old Oct 12, 2007 | 01:34 PM
Yako's Avatar
Yako
just sand the clear coat with some of the yellow sand paper then just add the primer and after it all dry the color u want let it dry again and then the clear coat
Old Oct 12, 2007 | 02:26 PM
technical18
i dont plan on ordering the front and rear pieces until january, and ill paint and install it all at one time. so ill just take my time sanding downto the plastic until then.
Old Oct 12, 2007 | 02:41 PM
Freerider's Avatar
Freerider
How I did my lip kit was I sanded off the clear coat with very fine sand paper. Be careful to no cut through the red powder coat too far. Its really easy as there is not a lot of paint on there.
Why leave the paint on there? The lip kit pieces are made out of a material that requires a certain primer to bond and paint to bond. once the paint is on there, you can apply a coat of other types of paint to bond.
Old Oct 12, 2007 | 02:57 PM
technical18
ORIGINAL: Freerider
ok thanx.
