Ignition Lock
Old Oct 13, 2007 | 04:23 PM
Magee99's Avatar
Magee99
Default Ignition Lock
Hey everybody, new to the site and having some problems with my 2002 RT. My key goes into the igntion but won't turn. The wheel lock is not on so I know it is not that.
It has happened before but ater a couple of minutes of jiggling it worked. Did the same thing for another day or so and then stopped completly for a few months
Any suggestions would be greatly appreciated.
Brad
Old Oct 13, 2007 | 05:06 PM
Yako's Avatar
Yako
Default RE: Ignition Lock
u using a copy or factory key? i think the factory keys have some kind of magnet and to get a copy ull need to go to the dealer so they can get u a new one and program it or something like that, but try with the original key
Old Oct 13, 2007 | 06:11 PM
Kalevra's Avatar
Kalevra
i know!!!
hit the top of the butt/head of the key while it's in the ignition (as if you were to jam it in) hit it fairly hard. your tumblers are sticking, it will knock it loose
Kalevra's Avatar
Kalevra
it happenes to me every once and awhile
Old Oct 14, 2007 | 08:32 AM
bone33's Avatar
bone33
you need to lubricate your tumblers. buy a bottle of graphite lubricant at the hardware store. put some on your key and also squirt some into the tumblers directly. work it in and out and add more as you go,in a minute or soit will unstick and work real smooth. this stuff is a black powder and it is sort of messy so i suggest that you hold a damp towel just under the ignition when you put it in there. let us know how it goes.
Old Oct 14, 2007 | 01:51 PM
Adionik's Avatar
Adionik
ORIGINAL: bone33
Graphite makes lubricant?
