Aftermarket alarm small problem
Old Oct 16, 2007 | 01:36 PM
neon03se's Avatar
neon03se
Default RE: Aftermarket alarm small problem
ORIGINAL: contagious19
probably a loose wire in the brain but u should take it to da place where u got it installed. if u have a reciept they should help u
i can't find the receipt lol
Old Oct 16, 2007 | 01:38 PM
swimmer07's Avatar
swimmer07
ouch, thats no good
Old Oct 16, 2007 | 01:39 PM
AirWolf's Avatar
AirWolf
The place where you got your alarm and installed probably has you in there computer system and they always have a copy of your receipt.
Old Oct 17, 2007 | 02:26 AM
lilsincere03's Avatar
lilsincere03
ORIGINAL: neon03se
the parking light wire most likely is either a white wire with a fuse attached to it or a brown wire with a fuse attached to it. seeing that this is a neon most likely it it was caught in the drivers kick panel orrrrrrrr take the bottom dash piece off and trace it from the brain. also the wire colors and what they do is written on the back of the brain. FIND THE BRAIN lol
Old Oct 17, 2007 | 02:53 AM
neon03se's Avatar
neon03se
i found the shock sensor but no fuses by the kick panel
Old Oct 17, 2007 | 01:22 PM
lilsincere03
ORIGINAL: neon03se
follow the shock sensor harness back to the brain, there's only so many places you can put the brain in that car
Old Oct 18, 2007 | 01:57 AM
contagious19's Avatar
contagious19
ORIGINAL: lilsincere03
ORIGINAL: neon03se
+1
