Aftermarket alarm small problem
I wouldn't call it much of a problem, more of an annoying thing. When i first got my aftermarket car alarm, when it would arm/disarm, my parking lights and brake lights would briefly light up. Now for some reason they don't. I checked the fuses on the drivers side and under the hood and everything is working. I called the place that installed it and they said to look under the dash, I lifted the dash but didn't see any fuses at all. Anyone got any opinions? I want my lights to flash again lol
2003 Dodge Neon SE
2003 Dodge Neon SE
I hope that never happens to my new alarm sounds kind of wierd. Did you look at your info booklet that came with your alarm maybe theres something you can do tricky like in the booklet. Mine came with one and has helped greatly for me .
lol i just read the booklet and it shows nothing! it just says that the lights are supposed to illuminate when armed/disarmed. damn this is so annoying, anyone else know anything? maybe a fuse or something?
Trending Topics
Well since that didnt work just go to the place that put it in for you . You go there in person with your ride they are more likely to help you with your problem than on the phone . Thats got to work for you .
how about you take that out and buy another one. if you brought any DEI alarms viper, python, valet etccccc. they're much easier to fix because majority of audio shops sell DEI, they monopolize the industry and you wont have any problems like this with them. they can go a good ten yrs w/o problems and i **** u you not.
the parking light wire most likely is either a white wire with a fuse attached to it or a brown wire with a fuse attached to it. seeing that this is a neon most likely it it was caught in the drivers kick panel orrrrrrrr take the bottom dash piece off and trace it from the brain. also the wire colors and what they do is written on the back of the brain. FIND THE BRAIN lol
