rpm problem
Old Oct 16, 2007 | 08:43 AM
hecrov's Avatar
hecrov
Default rpm problem
I have a 2005 SXT my rpm in Parking gear or in neutral is 1400rpm w/o the AC turn on whern i turn on the Ac it drops to1000
the car have been like these for 4 days now
also when I put in Drive it drops to 1000
Can anyone give me some help of this is normal or if a should worry
Thanks
Old Oct 16, 2007 | 09:35 AM
ricerchik02's Avatar
ricerchik02
Default RE: rpm problem
Well, I know my ac makes my rpms drop fast when I'm driving. I have an mtx so I can't try my car to see what mine does in drive, only in neutral. Sorry [&o]
Old Oct 16, 2007 | 10:50 AM
swimmer07's Avatar
swimmer07
i have an '05 sxt also, and i'm pretty sure mine does the same thing.. i'll check it next time i'm in it.. (in college, no need to drive) but i'll get back with you
Old Oct 16, 2007 | 11:08 AM
hecrov's Avatar
hecrov
the Ac is not the problem what troubles me is the rpm with just the engine running the idle rpm in neutral or Parked is 1500 or 1400 right now. I know that it wasnt like that before it was always under 1000 rpm
Old Oct 16, 2007 | 11:25 AM
swimmer07's Avatar
swimmer07
you might just have to go in and adjust the throttle line
Old Oct 16, 2007 | 12:19 PM
Adionik's Avatar
Adionik
Check if you have a vac leak
Old Oct 16, 2007 | 12:34 PM
03neonRT's Avatar
03neonRT
ORIGINAL: hecrov
You have a vacuum leak.
Old Oct 16, 2007 | 02:39 PM
hecrov's Avatar
hecrov
how do I check that?
Old Oct 16, 2007 | 04:05 PM
03neonRT's Avatar
03neonRT
Buy some throttle body cleaner, turn on your car, then spray the cleaner around the intake manifold, throttle body, and vacuum lines. When the engine changes "tone" from the spray thats where the leak is coming from.
