turbo burning oil?
Old Oct 16, 2007 | 08:21 PM
redbirdhky6's Avatar
redbirdhky6
Default turbo burning oil?
well this is mostly a question for graphite or anyone else who has ran a turbo...but about 3 weeks ago my car started burning oil BAD.its throwing white smoke out of the exhaust and from somewhere near the turbo...its not really noticable on the dipstick though..any ideas on what this could be
Old Oct 16, 2007 | 08:30 PM
03neonRT's Avatar
03neonRT
Default RE: turbo burning oil?
Are you sure its white smoke or bluish smoke?
Old Oct 16, 2007 | 08:32 PM
GrApHite03's Avatar
GrApHite03
^^ what he said, also what turbo are you using out of curiosity?
Old Oct 16, 2007 | 08:38 PM
03neonRT's Avatar
03neonRT
I think he has the HRC 20g if I remember right...
Old Oct 16, 2007 | 09:38 PM
GrApHite03's Avatar
GrApHite03
ORIGINAL: 03neonRT
Oh ya... that's right.
redbirdhky6 - have you checked your oil feed lines and the connections to the turbo. Also take a look and make sure that the oil return to the pan is not kinked in any way. It should be as free flowing as possible.
Old Oct 17, 2007 | 09:36 AM
redbirdhky6
yea i am going to check for kinks in the lines when i get home tonight. hopefully thats all the problem is
Old Oct 17, 2007 | 12:35 PM
GrApHite03's Avatar
GrApHite03
ORIGINAL: redbirdhky6
Let us know what you find... if it is it could lead to bigger problems. Blown seals in the turbo, etc..
Old Oct 18, 2007 | 09:26 AM
redbirdhky6
i only got a chance to check briefly but i didnt find any real kinks, there were just a few twisted spots.thought it might help if i untwisted those places but its still burning oil...hopefully it wont be raining tonight so that i can get a better look, but anything else i should be looking for?
Old Oct 18, 2007 | 12:35 PM
tooslow's Avatar
tooslow
where did you tap the oil pan if it is too low it also cause it too smoke.
but if it aint that
it is probly a bad turbo sealsor head gasket if it is your head gasket you will problybe blowing out alot of oil out the breather.
Old Oct 18, 2007 | 11:04 PM
redbirdhky6
well i got a chance to check it out and its from the turbo. i dont believe its a seal though, there is a nut on each side of the housin and one side has came loose. seems like it would be easy to fix, just tighten the nut,right...but its not that easy. it was a pain in the *** trying to get a socket up there to tighten it so after a while i just gave up. im gonna try again with some better tools tomorrow, but at least i know where the prob is.
