Headlamp Fluid
Old Oct 21, 2007 | 02:17 AM
Yako's Avatar
Yako
Default RE: Headlamp Fluid
damn adionik gotto stop smoking for a while
Old Oct 21, 2007 | 04:32 AM
sparky1_2007's Avatar
sparky1_2007
wow, wtf are those people smoking...
blinker fluid, O pipes, power bands?????? wtf...
Old Oct 21, 2007 | 04:54 AM
GrApHite03's Avatar
GrApHite03
ORIGINAL: sparky1_2007
I have all three and am pushing at least 275whp... i can feel it in the butt dyno. expensive, but worth it!
Old Oct 21, 2007 | 07:12 PM
fjlover's Avatar
fjlover
sorry to ask but what is a headlamp fluid?
Old Oct 21, 2007 | 08:48 PM
Swordfish2Cowboy's Avatar
Swordfish2Cowboy
ORIGINAL: fjlover
Special fluid you add to your headlights when they start to get dim. Most people just replace the bulbs but you can also use the fluid. Some of the higher-end lights that are more expensive require it regularly, but for the cheap bulbs it's easier to just replace them. However, if you do use the fluid on the cheap bulbs, it helps them burn brighter and clearer.
Old Oct 21, 2007 | 10:02 PM
fjlover's Avatar
fjlover
how do you apply the fluid to the bulbs?
Old Oct 21, 2007 | 10:44 PM
Kalevra's Avatar
Kalevra
LMAO!!!!! this is great!! there are no such things
HAHAHAHAHHAHA whoever believed any of this has got to be gullible as ****!!
Old Oct 21, 2007 | 11:08 PM
Swordfish2Cowboy
ORIGINAL: fjlover
There is a reservoir behind each lamp. I dunno if you have to take the whole unit off because I just got my Neon on Sat and I haven't messed with it yet. Usually directly behind the bulb but sometimes off to one side. It doesn't take much, either.
Kalevra, you've never used the fluid? Most people don't but a few cars require them. I think I remember Adionik talking about his V-tech charged Neon using a lot because of a hole in the bottom of his headlamp fluid pan. You don't have to use the stuff but it's like washing your car. It makes it look nice.
Old Oct 21, 2007 | 11:10 PM
Kalevra's Avatar
Kalevra
dude, im not that gullible!!!! LMAO it's just a dumb *** market scheme to con people out of their money
Old Oct 21, 2007 | 11:19 PM
unclemike's Avatar
unclemike
I have a headlamp sitting on my display case that used headlamp fluid, aka kerosene.
