NEED SOME INSIGHT (HEEEELP) ON MY NEON
Old Oct 22, 2007 | 12:10 AM
FROMDA671's Avatar
FROMDA671
Default RE: NEED SOME INSIGHT (HEEEELP) ON MY NEON
LOL, SORI AGAIN.......EVERY 3,000MILE........
Old Oct 22, 2007 | 12:18 AM
Kalevra's Avatar
Kalevra
hahahahaha!! ok, got that settled...
problem one: check the belt/get a new one
problem two: A tapping noise is perfectly normal, as long as it's not too loud. it's just that the piston isn't fully warm and cold metal contracts, so it 'wobbles' slightly in there, nothing to worry about. it's a normal noise
Problem three. make sure you have the right weight oil in there 5w or 10w -30
Old Oct 22, 2007 | 12:24 AM
FROMDA671's Avatar
FROMDA671
SWEET, THE TAPPING NOISE ADVICE PUTS ME AT EASE........WITH THE BELT, I GOT A NEW ONE PUT IN (serpitine belt), IT COST ABOUT $100.......AND STILL SQUEAKS......WITH THE TYPE OF OIL???.....I TAKE THE NEON TO PRECISION AUTO AND THEY DO THE OIL CHANGE, SO I NEED TO FIND OUT WHAT OIL THEY USE..........WHICH ONE IS THE BEST?????
Old Oct 22, 2007 | 12:31 AM
Kalevra's Avatar
Kalevra
make sure the belt isn't over tightened.
and if a shop does the oil they probably used 10w-30
ask for 5w-30 and leave 1 qt out and put a qt of lucas oil additive for cars
Old Oct 22, 2007 | 12:43 AM
FROMDA671's Avatar
FROMDA671
SOUNDS GOOD, SO IS THE SPARK PLUGS OUTTA THE PICTURE?
Old Oct 22, 2007 | 12:50 AM
Kalevra's Avatar
Kalevra
well, you might want to invest in them. regular champions will do, but if you want to step it up at 12 bucks a plug, go iridiums
Old Oct 22, 2007 | 12:53 AM
FROMDA671's Avatar
FROMDA671
THANKS Kalevra, FOR THE INFO.......
JON PANGIE
Old Oct 22, 2007 | 12:55 AM
Kalevra's Avatar
Kalevra
no problem. I dont always have the answers. but dont be a stranger on the site. they're others that know alot more than me and are willing to help
Old Oct 22, 2007 | 12:58 AM
FROMDA671's Avatar
FROMDA671
COOL, I WONT..........I JUST WANT MY NEON TO BE PROBLEM FREE
THANKS AGAIN
Old Oct 22, 2007 | 01:42 AM
03neonRT's Avatar
03neonRT
Which belt did you have replaced, the AC/PS belt or the Alternator belt? If the squeaking is coming from the alternator belt and its properly tightened with a new belt, then the problem is the bearings for the alternators pulley. Like Kalevra said, the "tapping" you heard is just normal valvetrain noise for a Neon, so you dont need to wory about it.
As for the engine "working too hard at idle", did this woman give any justifications for her statement? In Any case though, its good to change the spark plugs every 30k miles and the wires if they seem worn in any way.
