help
Old Oct 22, 2007 | 10:08 PM
contagious19's Avatar
contagious19
Default help
well i was installin my B&M short shifter. wen i finished i tried it and it would grab gears. well i put da stock one back on and it did da same thing. after dat i looked at my tranny and one of da shifter cables was out and it looks like da thing da holds it down broke off. does anyone know any tips on how i can fix dis.
Old Oct 23, 2007 | 07:44 PM
contagious19
Default RE: help
anyone im in need
Old Oct 24, 2007 | 11:15 AM
Izero's Avatar
Izero
Default RE: help
wait so u broke the bushing or the cable? im totally confused about what you are talking about
Old Oct 24, 2007 | 07:35 PM
contagious19
Default RE: help
da shift cables didnt break just da connection to da tranny.da rubber partor plastic thing, watever it is, is wat broke.
Old Oct 25, 2007 | 01:49 PM
Izero's Avatar
Izero
Default RE: help
ohhhhhh thats no problem at all... well it is a problem and i wouldn't drive the car like that until you get yourself a set of boger shift bushings from Modern Performance.... just order a new set from them and you will be set as well as make your shifts a little better....
unless you are talking about the actual plastic part that holds the bushing then im not sure how you need to fix that.... but thats what those stupid short shifters
Old Oct 25, 2007 | 09:32 PM
contagious19
Default RE: help
well ima get those booger bushins from modern and i hope they help me out but it is da actuall plastic thing. da only thing left is da ring where it goes.
Old Oct 26, 2007 | 10:29 AM
Izero's Avatar
Izero
Default RE: help
ok there are black rubber bushings that are circular they slide into a little white hard plastic hoop that is connected to the shift cables.... now which is broken...?
Old Oct 28, 2007 | 04:12 PM
contagious19
Default RE: help
ok the circular rubber thing dat connects to da tranny from da shift cable
Old Oct 28, 2007 | 11:37 PM
Izero's Avatar
Izero
Default RE: help
yea thats the shifter bushing just get a new one and slide it right in or booger shifter bushings
Old Oct 30, 2007 | 12:42 AM
contagious19
Default RE: help
thanx for da help bro
