Clear Side Markers
Old Oct 26, 2007 | 11:11 PM
car12fan2003's Avatar
car12fan2003
Default Clear Side Markers
Does anybody have experience with installing clear side markers? It looks like its a pain. I know how to get them out (I have the factory repair manual) I'm just not sure how to get to them. Any help would be greatly appreciated.
Old Oct 27, 2007 | 12:05 PM
Yako's Avatar
Yako
Default RE: Clear Side Markers
all i did was removed the screws on the mudflat thing connecting to the bumper pull it out, uncliped stock side marker, pull it out unplug the cable replaced the bulb with the ones they come with, got new sidemarker, got it in place and used stock clip then got everything back the way it supposed to be, one at the time and it took less than 15 mins
Old Oct 27, 2007 | 12:06 PM
Yako's Avatar
Yako
sorry if it dotn make sence, im bad at trying to explain things
Old Oct 27, 2007 | 12:30 PM
DouglasSXT's Avatar
DouglasSXT
Just like Yako said, take those plastic tabs that hold the inside wheel well on... Once you remove then, all I did was pull it aside just enough to get at the side marker. There's a metalclip that holds the marker in place... Just need to remove that and it comes right out!
Side Note- I had a bit of trouble with both clips and used a really long screw driver from the top sideto help pry them out just enough so i could pop that clip off... Hope that helps out?
Old Oct 28, 2007 | 04:05 PM
contagious19's Avatar
contagious19
its pretty simple and they pretty much cleared it up for u. its like a .5 out of 10 on installation
