Go Speedracer, go!
Old Oct 29, 2007 | 12:33 PM
ricerchik02's Avatar
ricerchik02
Default RE: Go Speedracer, go!
Well I have been needing new tires. And I am worried about my suspension. It doesn't roll when I turn or dip when I stop though. It just seems to make more noise than it should. I kinda rattles but when I went to have it checked, they blamed it on my body kit being loose and tightened the bolts for me. But it was a free check so I don't believe it was thorough and they seemed a little unprofessional.
AirWolf's Avatar
AirWolf
I wouldnt say that I have crappy tires and stock suspesnion and never have her kind of trouble . Always have had control when I drove above 100 or so.
Old Oct 29, 2007 | 01:53 PM
NHARINTON's Avatar
NHARINTON
a tranny wont make a diffrence in how your car handles at high speeds..... tires and suspension and how you use the steering wheel and throttle / brake will....... if tires and suspension did not make a diffrence why wouldent nascar drivers just use stock suspension and tires???
When your car reaches high speeds the car starts to lift a little because of the air going under the car, that is where good suspension will hold your car down and good tires will keep it stuck to the road.....(and a wing and good front lip at speeds above like 130-140 for more down force.)
my car used to be a handful at 115 but when i got my tires/rims and Tokico suspension, it feels the same as when im driving 70-80.
Old Oct 29, 2007 | 02:13 PM
ricerchik02
Great, more money to spend! Lol, I have stock suspension so I'm guessing they suck.
Old Oct 29, 2007 | 03:21 PM
Freerider's Avatar
Freerider
last time I was at a track day, 120 didn't make my car any less harder to control. I have stock wheels, yokohama tires, and stock suspension.
Old Oct 29, 2007 | 03:26 PM
GrApHite03's Avatar
GrApHite03
It also doesn't help that body kits today are only made for looks and not aerodynamics. More than likely your kit was just acting like a giant snow plow and not helping to steady the car.
Old Oct 29, 2007 | 03:29 PM
03neonRT's Avatar
03neonRT
ORIGINAL: GrApHite03
Good point Graphite that hadn't occured to me...
Old Oct 29, 2007 | 03:45 PM
Adionik's Avatar
Adionik
ORIGINAL: 03neonRT
That's because you have a tiny brain. Now paint my rear driver caliper! And give me your rear sway bar bolts! Or atleast specs lol
Old Oct 29, 2007 | 04:01 PM
LowSlowNeon's Avatar
LowSlowNeon
ORIGINAL: Freerider
I was about to say the same thing. I notice no difference in handling between driving 118 and 50 down the same road, other then any sudden movement is amplified at the higher rate of speed.
Old Oct 29, 2007 | 04:12 PM
03neonRT's Avatar
03neonRT
ORIGINAL: Adionik
ORIGINAL: 03neonRT
Forget to take your meds again eh?
