looking for motor mounts
Hey if you open this thanks...
I'm looking for all of the motor mounts for a 2000 Dodge Neon, Auto Transmission. I perfer new ones but the ones that are the newest would work too. At idle my engine just rocks the whole car pretty bad. When you are going or accelorating its perfectly fine. So I don't quite know whats going on with it but I know all the motor mounts are cracked, they all need to be replaced. So please send me a message or an e-mail at Jordanm@WI.RR.com.
Thank you and have a good day
-Jordan Moddes
-Jordan Moddes
have you looked on ebay? i would take a look on there if you havent already... ive seen some on there before not too much either... some are used but usually not too bad.
I've seen some for as low as $25 shipped on FS forums on the org. I would check there. FS forums are the way to go if you don't get scammed.
Otherwise, consider motor mount inserts. Motor mounts will eventually crack again...and inserts fill them up. They're about $30 bucks and take around an hour to install the first time.
