Control arm bushings
Old Nov 3, 2008 | 10:51 AM
InPsychOut's Avatar
InPsychOut
If it's just the control arm bushings you need, these are what I was going to buy.
Link to Modern
Old Nov 3, 2008 | 10:58 AM
Izero's Avatar
Izero
is that one set for the front and rear or just the front?
Old Nov 3, 2008 | 11:46 AM
InPsychOut's Avatar
InPsychOut
That's just the front. I haven't looked into the rear.
Old Nov 3, 2008 | 12:54 PM
darthroush's Avatar
darthroush
Section Moderator
Originally Posted by Adionik
FOR THE LOVE OF GOD just have someone else do it.
I hit my head about 4 times and banged up the rest of my body pretty good....godamn ****ing neons ah;asdlkfjzl;sdkfhzl;dfjagfadf
ah!!!!!!!!!!!!!!!
I have been wondering about this since I haven't done it yet. If the price isn't too bad, I will probably just be taking it somewhere then, lol
Old Nov 3, 2008 | 06:36 PM
Izero's Avatar
Izero
so you cant buy the LCA bushings for the rear from modern without buying the WHOLE suspension bushing kit....?
Old Nov 3, 2008 | 11:28 PM
darthroush's Avatar
darthroush
Section Moderator
No, but here is the Prothane Part Numbers:
CONTROL ARM BUSHINGS, REAR
Year Kit Name Kit
(Neon, SRT-4))
95-99 Rear C-Arm Bushing Kit 4-301
00-06 Rear Trailing Arm Bushing Kit 4-304
Old Nov 7, 2008 | 09:05 PM
Dorin_82's Avatar
Dorin_82
...hahaha, this brings back some laughs
i did mine a while ago. in the process of doing it, i actually got so mad and frustrated, i felt like setting the hole car on fire. so u're ok adionik. gotta tell u, for 40$ i would have go straitgh to the guy, but i don't think he had any idea what he was getting himself into.
any way, i got the red ones from modern, i have them for about six months, and they are great. a friend helped me(not to set the car on fire), two minds are better than one. so, if u have some idea of what u are doing, and have some help, i recommend getting them and doing it yourself. when we finished, i was really happy, and even happier now cause i saw they were worth it.
and yeah, i couldn't get them on without a press (and belive me, i tried really hard). but once i got them on the control arm, right, both of my control arms went back on really easy. good luck
Old Nov 8, 2008 | 12:31 AM
OhNo2.0's Avatar
OhNo2.0
Ya press > no press
But if you really don't have access to a press you burn the old bushing out with a torch, cut the sleve(Do these bushings have metal sleves?) with the torch as well and if it's the sleved type you use anti-sieze, a block-o-wood and a really big hammer and pound those things in. if it's the unsleved type you clean the inside of the control arm out with a die grinder and a sanding wheel and make it shiney.
Use some lube to get it in I don't care if you use ky, but putting in a bushing without any form of lube(even if it's anti-seize) will mean disaster.
Trust me, I'm a Heavy duty mechanic, I've never done a neon control arm bushing but at least once a week I have to do a torque arm bushings/walking beam bushings or trifunctional bushings that are the size of your frigging head.
Makes me giggle when you say neon bushings are hard.
Old Nov 10, 2008 | 05:51 PM
Adionik's Avatar
Adionik
I didn't use a press, my problem was getting a torcher hot enough to burn the bushings off. Once I did, the rest was a cake aside from putting the control arm back in...
Old Nov 20, 2008 | 11:53 AM
milkydischarge's Avatar
milkydischarge
Thumbs up
Go Pablo!!!!
