magnum intake..
Old Nov 4, 2007 | 09:50 AM
THExRED's Avatar
THExRED
Default magnum intake..
will the rt intake match up to an 05 sxt head
Old Nov 4, 2007 | 10:00 AM
THExRED's Avatar
THExRED
Default RE: magnum intake..
and what modificatioons will have to me done
Old Nov 4, 2007 | 02:08 PM
Adionik's Avatar
Adionik
It should match up. The secondaries (AKA NEON VTECH FTMFW!) kick in at higher RPM's and are motorized...so you'd have to control that.
But from what i've heard, it's supposed to directly bolt up. Might need a little work on the passenger side to fit.
Old Nov 5, 2007 | 04:25 PM
03neonRT's Avatar
03neonRT
The intake ports are the same and it will bolt up, you'll just need a Mag gasket. Plus, you'll need to wire up the secondaries with a RPM window switch and a TPS/WOT switch since the PCM wont be controlling them.
