help electrical problem
Old Nov 4, 2007 | 10:05 AM
brewski86's Avatar
brewski86
Default help electrical problem
I have a 2000 neon that started doing some strange things. the dome light comes on, the door locks arelocking and unlocking by them self and now the car alarm goes off when it wants. does anyone know what is going on and what I can do to fix it. Any help would be great.
Old Nov 4, 2007 | 11:44 AM
NHARINTON's Avatar
NHARINTON
Default RE: help electrical problem
hire a priest, and have an excercism...... sorry cant help ya, thats a weird problem but im sure someone can help!!!
Old Nov 4, 2007 | 02:36 PM
brewski86's Avatar
brewski86
ttt
Old Nov 4, 2007 | 04:23 PM
mrdollins's Avatar
mrdollins
is it the factory evs alarm on it? If so check your battery in your remote and see if that helps if not there is something wrong with the module and it's causeing it to go hay wire on you. They factory alarm is easy to by pass your just have to pull the panel on the lower dash on the drivers side and you evs box should be right down there, and you have to loop the yellow wire with the FACTORY wire going to the box. That wire is the ignition wire that controls the ignition kill switch with the alarm if its stolen. If you need a module I have mine from when I took out my alarm.
Old Nov 4, 2007 | 08:06 PM
brewski86's Avatar
brewski86
Thanks mrdollins for the info, I sent you a pm.
Old Nov 6, 2007 | 12:35 AM
brewski86's Avatar
brewski86
ttt
Old Nov 6, 2007 | 01:10 AM
Kalevra's Avatar
Kalevra
ORIGINAL: NHARINTON
ahhahahah +1
Old Nov 12, 2007 | 06:56 AM
smikes's Avatar
smikes
Back to the top as my 2000 has just started doing this also.Any help appreciated!!!
Old Nov 15, 2007 | 05:15 PM
mistykblue22's Avatar
mistykblue22
I have a 2000 Neon as well. I had that problem a couple months ago and it all of a sudden stopped doing it by itself.
It would happen while I was on the highway driving, quite embarrassing I might add.
Good luck.
Misty
