some electrical issues.....
Old Nov 13, 2007 | 04:18 PM
NHARINTON's Avatar
NHARINTON
Default RE: some electrical issues.....
no, it justresets the trip
Old Nov 13, 2007 | 04:57 PM
Pharmboy's Avatar
Pharmboy
2nd vid is the gauge self test, also runs when you hold the trip button while keying the car to run, it usually happens when battery is low also. Definately an electrical problem, I would lean toward a bad ground ("then i slow down to stop, the stereo turns of untill i get back on the gas,"), but definately get the alternator checked out as it could be a field generator problem as well, where it would put out correct voltage at higher rpms only.
Old Nov 13, 2007 | 05:01 PM
NHARINTON's Avatar
NHARINTON
the ground is good as i just replaced it, i pull the alt this weekend and have it tested!
Old Nov 15, 2007 | 02:00 PM
NHARINTON's Avatar
NHARINTON
ok before i go out tonight and buy an alt.....
when i dissconnect the battery when the car is running, should it die? anyways it does, and if i remember correctly that means the alt. is dead....
but then why does the car still start time after time? Its like the alternator is charging a little bit but not enough.....
Old Nov 15, 2007 | 02:36 PM
Kalevra's Avatar
Kalevra
could be only putting out sufficent power to sustain a charge, when it sits that charge can build slightly enough to start it
Pharmboy's Avatar
Pharmboy
yeah, with the field generator problem in some cases it will still charge when the engine is revved, but dosen't have any output at idle.
Old Nov 15, 2007 | 03:12 PM
NHARINTON's Avatar
NHARINTON
ahhh, damn neon, this is gunna suck, its snowing and last night i couldent get me garage heater to work...... its gunna be a cold night for me!
Gunna pick up the alt when i get off work for $129.99 + 69.99 core. I have an extra alt laying around that has a bent shaft so ill just give them that one for the core..... thanks ill let you all know how it goes!
Old Nov 15, 2007 | 07:15 PM
neon03se's Avatar
neon03se
i noticed that when i brake, my headlights dim, also when i switch gears, the headlights dim as well. when the door is open the dome light flickers a bit. did you experience any of this as well?
Old Nov 15, 2007 | 08:03 PM
NHARINTON's Avatar
NHARINTON
ORIGINAL: neon03se
Yeah it has always done that....
anyways i just put the new alternator in and still the same problems...... leaving to parts place to have the old one tested and pick up a new battery...
I put a voltmeter on it and the gauge goes between 9-15 volts when the car is running, (pulses with the lights)when i shut it off, its at about 8...... so i think it was just a battery, well see the damn thing is only 7 mths old................
Old Nov 15, 2007 | 08:54 PM
NHARINTON's Avatar
NHARINTON
DAMNIT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!
JUST A FUC*ING BATTERY!!!! so yeah i took the old alt in and it was putting out just below were is should but it passed, so i got a battery, and now its good to go!! YEAH! $200 later.......
fixed all the problems i have been having, the car was ******* of the line, was really slow to shift and when you put it into gear it took about 3-4 sec. to go in..... now its good as new!!! Its amazing what a good battery can do!!!
