Check Engine Light
Old Nov 14, 2007 | 07:57 PM
neondummi's Avatar
neondummi
Default Check Engine Light
Does anyone know about the check engine light coming on after so many miles? If so what does this mean? My dad said it might be the oxygen sensor going bad??? Let me know what you all think
Thanks!
Old Nov 14, 2007 | 08:28 PM
Kalevra's Avatar
Kalevra
Default RE: Check Engine Light
what code is it throwing?
turn the key, without starting the engine on>off>on>off>on it will display a code in the odometer, write it down and let us know. we cant help you without knowing that code
Old Nov 14, 2007 | 08:43 PM
Adionik's Avatar
Adionik
Do the little switch dance that Kalevra said, takes about 10 seconds and write down the code. Post it here and we can usually pin point it fairly quick.
Most of us have gone through every possible neon problem. (Even some you might have thought impossible)
Old Nov 14, 2007 | 11:17 PM
Mike594sxt's Avatar
Mike594sxt
If it says P1684 get ready to look at your CEL from now on. lol.
Old Nov 15, 2007 | 01:01 AM
contagious19's Avatar
contagious19
ORIGINAL: Mike594sxt
i had dat code and it went away and it never came back since
Old Nov 15, 2007 | 01:07 AM
Pharmboy's Avatar
Pharmboy
ORIGINAL: contagious19
guys P1684 won't set the light and it only means you lost battery connection within the past 50 starts. got that code yet neondummi?
Old Nov 15, 2007 | 07:19 AM
Mike594sxt's Avatar
Mike594sxt
Is that what that code means? I always go past 50 starts though and it stays on, itsso annoying. [:'(]
Old Nov 15, 2007 | 10:24 PM
neondummi's Avatar
neondummi
Sorry guys...what is a CEL? I will try to code thing when I get home from work tomorrow and let you all know what I find out. I've heard several ppl say that once you hit so many miles the light turns on anyways...is this true?
Old Nov 15, 2007 | 10:26 PM
Pharmboy's Avatar
Pharmboy
no!!!... and CEL is just check engine light,can also useSES-service engine soon
Old Nov 15, 2007 | 10:32 PM
neondummi's Avatar
neondummi
Thanks... I thought about the what CEL meant after I posted that and feel kinda silly. I do need an oil change badly...just had two tune ups in a row because a place put in cheap spark plugs and messed the first tune up royally...just had a new raditor put in, those things are expensive, possibly could be something else though
