advice
Old Nov 16, 2007 | 11:22 PM
NeonPerformance88's Avatar
NeonPerformance88
Default advice
Hello you guys im here once again needing your opininon... im thinkin about cahngin but stock tires and stock wheels but i know what size i should get what size would you guys recommend me.... and is there anyting else i should know? what tipe of tires??? btw im keeping stock struts for now...
Old Nov 16, 2007 | 11:42 PM
03neonRT's Avatar
03neonRT
Default RE: advice
I would suggest 17x7 wheels with 215-40-17 tires (or 205-40-17). As for which tire to get, well, that depends on your budget. You'll want some kind of all-season unless you plan on having a winter-specific set of wheels. I have Toyo Proxes 4 Ultra-High Performance All-Season (UHPAS) tires on my 17's and they are tremendous.
Old Nov 17, 2007 | 12:06 AM
NeonPerformance88
Default RE: advice
hmm i was lookin at 16's at the tire rack but if you say 17s would look nice then im goign to search for those.. thanks btw what about the offset what should it be 35mm?
Old Nov 17, 2007 | 12:09 AM
NeonPerformance88
Default RE: advice
i was lookin at these http://www.tirerack.com/wheels/Wheel...mp;showRear=no
with these...
http://www.tirerack.com/tires/tires....cleSearch=true
03neonRT's Avatar
03neonRT
Default RE: advice
You should stick to the 35mm-40mm range for the wheels offset.
Old Nov 17, 2007 | 08:32 AM
TN.Frank's Avatar
TN.Frank
Default RE: advice
If you want to keep a bit of ride comfort then stick with a good 16", I've read that 17" can have a harsher ride because of less sidewall to absorbe the bumps. Here's a couple good places to check for tires and rims, very decent prices.
http://www.performanceplustire.com/
http://www.wheelmax.com/
Here's a set that I really like:
http://www.performanceplustire.com/p...377#prodAnchor
Old Nov 17, 2007 | 08:49 AM
NeonPerformance88
Default RE: advice
mmm thanx
