Small car alarm issue
Old Nov 20, 2007 | 12:12 PM
ricerchik02's Avatar
ricerchik02
Default Small car alarm issue
When I first got my alarm, it would flash the parking lights when arming/disarming. Recently it stopped. I want it to work again! All my fuses are fine and all but one bulb is fine. Any suggestions? Its an Avital 2 stage alarm.
Old Nov 20, 2007 | 12:21 PM
neon03se's Avatar
neon03se
Default RE: Small car alarm issue
i have the same problem, but could never find the "brain" of the alarm to check the fuses, and haven't had a chance to take it to the installer. the alarm itself might have a fuse (thats not under the fuse box or on the side of the drivers side panel) but like i said, i never personally found it.
Old Nov 20, 2007 | 12:28 PM
ricerchik02
[&o]Well thats not cool, lol. Its cold and I hate to be searching all over the car for whatever I need to fix/replace.
Old Nov 20, 2007 | 03:26 PM
ricerchik02
Oh c'mon, someone had to have figured this out before! [sm=helpout.gif]
Old Nov 20, 2007 | 03:51 PM
Pharmboy's Avatar
Pharmboy
it's an aftermarket alarm, they're all different, It's probably a loose connection to the wires coming off the headlight switch, should be a connection coming off the black w/ yellow stripe wire near the base of the column, check it it's probably loose. be sure to check fuses too there should be at least one on the alarm unit itself.
Old Nov 20, 2007 | 05:44 PM
contagious19's Avatar
contagious19
my siren has not workd for over a year, im tired of tryin to fix it so ima buy a new one
Old Nov 20, 2007 | 06:43 PM
mrdollins's Avatar
mrdollins
well if your looking for the brain check under the drivers side part of the dash, it's the only place they can actually put it plus it saves on cost when it comes to wires.
Old Nov 21, 2007 | 09:49 AM
ricerchik02
Cool, I'll check it out since I'm gonna be out working on the car later anyways.
Old Nov 22, 2007 | 11:52 AM
blocks885's Avatar
blocks885
i installed my alarm. most installers put it underneath the steering wheel. right above the pedals behind the panel. there should be a box there. check around that area. it's the easiest place to put them, without having too much difficulty since all the access to the wires are there.
do you have an alarm that remote starts too? then it'll be where i'm telling you.
Old Nov 24, 2007 | 04:26 PM
ricerchik02
No remote start.
I found the "brain" of the alarm system and there is only one obvious fuse. Its not blown. What else should I look for?
