turboing help
Old Nov 21, 2007 | 05:36 PM
blackflame's Avatar
blackflame
Default RE: turboing help
I wasn't sure if megasquirt got rid of the speed limiter. I know it gets rid of the rev limiter. I have a MTX btw, so thats no problem. Just to make sure....the regular 2.0l non-magnum can never be as good as the magnum right? I mean they can both be made better but its not just the cam, valve springs, and replaceable stuff that makes the magnum head better right?
Old Nov 21, 2007 | 06:57 PM
Freerider's Avatar
Freerider
ORIGINAL: blackflame
- The magnum head flows better. Thats the main reason people pick it up. It is cheaper than sending in a head to be ported and polished, and it does the job amazingly well. You can then go an upgrade the cam, valve springs, and you would see an amazing difference.
-Also, using the STOCK MTX clutch, it will wear out within weeks of any hard driving. You should upgrade to atleast a stage 3 clutch if you want to get on the gas a little bit.
-MS will run like a seperate ECU. It won't have anything unless you set it in the programming.
Old Nov 21, 2007 | 08:27 PM
2004neonR/T's Avatar
2004neonR/T
So i havent taken my head off I have the Magnum Head is the room for it to be ported and polished even more???
Old Nov 21, 2007 | 09:51 PM
Freerider's Avatar
Freerider
ORIGINAL: 2004neonR/T
yes
Old Nov 22, 2007 | 03:04 PM
blackflame's Avatar
blackflame
yeah, I knew I had to get a new clutch after that. A clutch that would hold 300hp would be nice. How much hp does a stock clutch hold? I can baby the shifts no problem for a while.
I think i will just save and look for the adapter. If I can't find it by the time I have like $3000 I think I will just swap out the engine. If I pay to have the adapter made then it would cost more to turbo instead of doing the swap. And I can swap to a newer and according to graphite "dumb proof" engine lol.
