EVAP Fault: P0441
Old Nov 23, 2007 | 09:07 AM
SR71's Avatar
SR71
Default EVAP Fault: P0441
Check Engine Light: Code- P0441
EVAP system incorrect purge flow. Excessive vapor flow detected during EVAP operation.
First response is to tighten gas cap. 2nd response- replace gas cap.
Possible vacuum hose leaks (anyone ever had these and where?)
Following a previous post on this issue, I'm going to replace the following:
- Vapor Canister Duty Cycle Purge Solenoid- $41.50 ($31 employee cost)
-Natural Vacuum Leak Detector (NVLD)- $$43.50 ($32 employee cost)
Re-set CEL... disconnect NEG battery cable 5-10 min.
Any other suggestions ?
Thanks!
John
Old Nov 23, 2007 | 03:35 PM
tuffone20's Avatar
tuffone20
Default RE: EVAP Fault: P0441
I got that code for the 2nd time, 1st time we replaced the Vapor Canister Duty Cycle Purge Solenoid, 2nd time we couldn't find out what was causing it as everything was working just fine, so we cleared the code and so far it's been fine.
Old Nov 24, 2007 | 11:53 AM
tankhardrive's Avatar
tankhardrive
i get that code every now and then but it will kick on then kick off so i donno i dont think anything is wrong everything is running fine sooo i just think its crazy
