Droping my car. Need your HELP
Old Nov 28, 2007 | 11:41 PM
JosephLo123's Avatar
JosephLo123
Default Droping my car. Need your HELP
i'm planing to drop my car 1 1/2 in. is that going to be too low? is it going to scratch the bottom when i go over bumps and curves? ohh and isinstalling it hard?do any of you have suggestion on wich type of springs i should get? i want something that is good quaulity but not that expensive. it would be great if you guys could help me out. thanks
Old Nov 29, 2007 | 12:11 AM
csmaverick07's Avatar
csmaverick07
Default RE: Droping my car. Need your HELP
I want to do the same thing, but with a 2" drop. I've never done it myself, but I know that you'll need to rent a spring compressor, unless you have one, and some other tools to do it. Pepboys can do it for you too if you'd rather not do it yourself. Personally I want to go for a set of Eibach springs, which I've seen for around 250.
Old Nov 29, 2007 | 12:16 AM
ewetho's Avatar
ewetho
I have Vogtland and they seem to be just fine. Never had a problem even in the winter here in Chicagoland.
Just like doing struts, just realign when done.
Old Nov 29, 2007 | 02:01 AM
neon03se's Avatar
neon03se
2" drop is too much, trust me i have that and its not a pretty sight sometimes. I even cracked my bumper coming out ofa parking lot yesterday. I would like to have stock back,I don't like the look of stock but the ride is a lot better. I am thinking that a 1.5 drop would be better.
Old Nov 29, 2007 | 02:46 PM
technical18's Avatar
technical18
its a pain in the *** to install if its your first timeand especially if you are without air tools/impact wrench.
i sat here and read all these posts about it only taking maybe 6 hours, 2 hours for the 1st one until u get the hang of it. then 4 hrs for the other 3.
bull ****! i started at 9Am and didnt finish til 7-8pm. maybe an hour was spent going back/forth toautozone cause i didnt have all the tools. (make sure if u dont have access to an impact wrench you have the special little "wrench-extender-sparkplug socket-monkey wrench-socket setup" or w/e it was)
one of the most hardest (exhausting) things i've ever had to install on my car.
NEVER AGAIN!![:@]lol
.....just my 2 cents
Old Nov 29, 2007 | 02:50 PM
technical18
i have a 1.5" drop...rides kinda rough at first until u get used to it, but thats expected when u give up comfort for handling.
I have tokico blue struts with kazera springs...i dont beileve they make kazera springs anymore so ive heard Eibach are good.
I also agree 2" would be too big of a drop especially if its your everyday car.
1.5" was just right for me.
Old Nov 29, 2007 | 03:28 PM
tankhardrive's Avatar
tankhardrive
i was planning on installing me drop 1.5 inch over my christmas break.... i took my car over to tire kingdom and they wouldnt install it for me prob cuz i didnt buy it from them.... id rather not spend all day doing it specially since i dont have all the tools any one know any places that would install? some one above said pepboys? i have the ebaich and tokyo blues.... if i cant find a place to install ill be going at it in oooo 2 weeks....
Old Nov 29, 2007 | 03:57 PM
neon03se's Avatar
neon03se
which eibach springs do you have?
Old Nov 29, 2007 | 04:07 PM
technical18
ORIGINAL: ewetho
i was surprised i didnt have to get my car realigned after i did my install... and i was doing everything short of jumping up and down on the knuckles to get the holes lined up and everything in place to be bolted.
Old Nov 29, 2007 | 07:19 PM
tankhardrive
ORIGINAL: neon03se
think that was to me ummm the pro kit
