Water in the trunk and on floor.. sxt 2004
Old Nov 29, 2007 | 08:54 AM
Dragula's Avatar
Dragula
Default Water in the trunk and on floor.. sxt 2004
hi all,
i am having a problem with getting a LOT of water in my trunk and on my back floor behind driver. i mean a lot like 1 to 1.3 inches of water! any ideas how to fix this and what is causing it ? please help!
thanks
Old Nov 29, 2007 | 01:43 PM
KDRNolan's Avatar
KDRNolan
Default RE: Water in the trunk and on floor.. sxt 2004
Do you have a spoiler on your trunk?
Old Nov 29, 2007 | 02:52 PM
technical18's Avatar
technical18
from what i understand, check these three seals:
1) Spoiler
2) Trunk
3) Tail light gaskets
U can check them by having someone spray a water hose over the areas while u lay in the trunk looking for water coming in.
Old Nov 29, 2007 | 02:54 PM
technical18
i had water coming in from my tail lights. so i used a silicon caulk type stuff to line the gaskets and press them in place. it helped. hasnt leaked since.
Old Nov 29, 2007 | 03:46 PM
Dragula's Avatar
Dragula
hi all
thanks for the reply's
is there a web site i can go to that maybe show's me how to take apart my taillights and fix the seal and or spoiler? im not real handy with cars..
thanks Dragula
Old Nov 29, 2007 | 04:11 PM
technical18
u dont have to take apart the tails.
behind the carpet, in the trunk, near the tail lights should be 3 black plastic screw things (lmao) that hold in on.
unscrew those and the tails will pop out. the gasket will be a rubbery foam material in between the tail light and car body.
Old Dec 2, 2007 | 07:05 PM
Flash_Gordon2392's Avatar
Flash_Gordon2392
What's up man!That has to me before with my car and I own a 2004 SXT.And Iwas getting water in my trunk and back seat's floorand front seat floor.I was told to change the weather stripping.
Old Dec 15, 2007 | 03:10 AM
dodgedude88's Avatar
dodgedude88
or you could just revitalize the rubber seals by spraying silocone spray on them it saves money rather than buying news stuff.
