some one please help
RE: some one please help
sorry i had to leave if u tap the coimputer and it works there could be a lost connections in it and if u tap the gas tank sometimes the vibrations from the gas can cause the fuel pump to kick back on and also take a volt meter to ur battery and c if thats charged also check ur crank shaft sensor make sure thats plugged in and also try ur altanator
Taping stuff also helps with wiper motors and heater motors if u tap them and they turn back on its time for a new one
i gave up and took it to the mech again i am sick and in much pain to be ****ing around with what ever mistake that ****ing mech did that *** hole as had my car for 2 days now and still hasnt looked at my car that ***** ****er
once he fixxes it imma go to another mech or a dealer and have the look over the car compleatly to make sure he aitn ****ing me doggstyle that ***** ****er would the steership charge me a arm and leg for that?
also i hope its not the comp cuz ill be out of a car for a while since well it will take 6-8 weeks for a new comp
and i gatta get 500 bucks
ORIGINAL: noen_newbe
when these ****ers dont respond to you and your topic is pushed down the page you type bump to bump you back up to the first spot so more people has the chance to read it
calm down and grow up... one search on the org and i could probably find your answer, but since you got your panties in such a bunch you can do it yourself. Khama is a bitch, so i see a very violent *** raping from that mechanic. I wouldn't count of him using lube either.
