car not idling... not driveable, HELP!!
Old Dec 10, 2007 | 11:49 PM
Pharmboy's Avatar
Pharmboy
Default RE: car not idling... not drivable, HELP!!
when did you last fill the gas tank up? is bad fuel a possibility? I'm trying to figure out that lean condition. Other things I'd look at would be the O2 sensor voltage and maybe a quick voltage check on the tps (not that I think that would be the prob, easy to check with a scanner though)
Old Dec 10, 2007 | 11:58 PM
sirvroomsalot's Avatar
sirvroomsalot
my bad in not specifing that, issue started at about 3/4 tank, my half hour trip to house took 1/4 tank for a 20 mile trip
Old Dec 11, 2007 | 12:06 AM
Pharmboy's Avatar
Pharmboy
I forgot to include a quick map sensor check, though i'd still expect the car to run.
Old Dec 11, 2007 | 12:12 AM
sirvroomsalot
do you know where abouts the sensor is located, my manual has eluded me at the moment
Old Dec 11, 2007 | 12:14 AM
sirvroomsalot
update:
managed to get carto run at open throttle but only manage to idle at 400 RPM
Old Dec 12, 2007 | 08:02 PM
ewetho's Avatar
ewetho
When it does run, does it sound like it is running on all 4 or is it still missing??
Old Dec 12, 2007 | 09:30 PM
sirvroomsalot
removed the MAP sensor and the engine started and ran at a relitivle normal idle, can not run throttle open or else engine bogs down, dealer posts approx $133 for the map sensor, anyone know if theres a place to get it cheaper?
Old Dec 12, 2007 | 09:34 PM
Pharmboy's Avatar
Pharmboy
glad you found it
Old Dec 13, 2007 | 01:29 AM
mrdollins's Avatar
mrdollins
Ok my questions is, are you sure it is the map sensor? I have had the same problem before and it always seemed to be the cam position sensor. As far as running lean pull your bank 1 O2 sensor clean it and see if that helps with running lean.
