oil light
Old Dec 15, 2007 | 03:00 PM
dcorwin822's Avatar
dcorwin822
Default oil light
G.f's '04 neon base model oil light comes on when we start it. Turn the engine off and back on and it goes away. Dealer recently *past 2 weeks* changed the oil. Cold NY climate. Any idea's?
Old Dec 15, 2007 | 03:10 PM
Kalevra's Avatar
Kalevra
Default RE: oil light
try 5w-30 in it, or 5w-20?
Old Dec 15, 2007 | 04:27 PM
LowSlowNeon's Avatar
LowSlowNeon
I would check level of oil first.
Old Dec 15, 2007 | 07:12 PM
dcorwin822's Avatar
dcorwin822
level is fine it was just recently dealer changed. i usually do it but with the weather every chance i have to do it its been poor out so i said screw it and took it to the dealer.
Old Dec 19, 2007 | 10:33 PM
dcorwin822's Avatar
dcorwin822
bump? any ideas anyone?
Old Dec 19, 2007 | 11:06 PM
ewetho's Avatar
ewetho
Could simply be a failing sensor. Would advise having it checked out.
Old Dec 20, 2007 | 02:06 AM
Dimas's Avatar
Dimas
take it back to the dealer and ask them wtf did they did to the car for the light to come on.
Old Dec 20, 2007 | 10:53 AM
LowSlowNeon
If oil level is fine I would assume its the oil sender as well. It will kick the oil light on when the pressure drops too low, so if you the proper amount of oil, the sender is probably bad. I'd get it checked out though.
Old Dec 20, 2007 | 01:00 PM
Izero's Avatar
Izero
i hope that your oil pump isnt messed up... b/c a low oil pressure could also be causing the light to come on.... i would go back to the dealer and flip out till they fix it for you....for free .... lol
