depending on what year and such thats a good site where i will be getting mine from here in a little.... you can see which one will be good for your car. hope this helps.
First thing to do is get a Fidanza lighten flywheel so you can use a Non-Modular(and less expensive) clutch set-up. Then you can get the Fidanza Stage 4.2(middle stage out of the three they offer) which is suppose to be good for 300 HP. That should be more then enough and if you burn a disc you can simply replace the disc and use the same TB and PP so you'll not have to spring for the parts you don't need. Flywheel will run around $350, clutch kit will run around $350 so for $700 you'll have a killer set-up which is only about $100 more then the Modular Clutch Kit. JMHO, YMMV.
