WILL THIS WHEEL FIT?
Old Dec 1, 2004 | 11:26 PM
Ryan's Avatar
Ryan
Default WILL THIS WHEEL FIT?
HI I AM ABOUT TO ORDER WHEELS FOR MY 2001 DODGE NEON SE THEY ARE 18X7.5 5X100 AND 45MM OFFSET.. DOES ANYONE KNOW IF THEY WILL FIT PROPERLY WITHOUT SPACERS ECT. THANKS
Old Dec 2, 2004 | 12:23 AM
elric62285's Avatar
elric62285
Default RE: WILL THIS WHEEL FIT?
should... just don't go any bigger
Old Dec 2, 2004 | 12:35 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Yeah, they'll fit but you are pushing it with them. Good luck and get pics when youa re done. I odn't think I've ever seen a 7.5 width rim on a Neon before. The widest I've seen was 6.5.
Old Dec 2, 2004 | 03:10 PM
GroundControl's Avatar
GroundControl
my friend got 18 inch rimz on his neon. real thin tire. he cracked 2 of his rims already i got 17 and there fine.
Old Dec 2, 2004 | 03:21 PM
techmanbd's Avatar
techmanbd
I thought was that if you went a 17 or higher you would have to do some aftermarket work on the suspension in the back so they would fit, is my thinking correct?
When I can afford it, I think I am just going to go with 16's because I would like a little meat on the tires because I tow a trailer once in awhile.
Old Dec 2, 2004 | 05:50 PM
GroundControl
i should of went with a smaller tire. i got 205/17 zr i think. they rubbed the back and the front was fine. i had to put a weel spacer in the back and i did alittle grinding. its nice now.
Old Dec 6, 2004 | 03:41 AM
99NEONCASPER's Avatar
99NEONCASPER
YOU SHOULD ONLY GO WITH 17" ANY HIGHER AND YOU COULD MESS UP YOUR ABS SYS AND YOUR SPEEDO. BUT YOU SHOULD THINK OF THIS.
MOST OF YOUR COMP, WORK WITH YOUR ABS AND YOUR SPEED. YOU SHOULD CHECK AND SEE IF 18" WILL DO THIS IF NOT GO FOR IT.
GOOD LUCK
Old Dec 6, 2004 | 03:59 AM
Cr@zy Squ33
Turn off the caps lock.
