inspection time HELP!!!!!!
Old Jan 8, 2008 | 07:19 AM
lostcause's Avatar
lostcause
Default inspection time HELP!!!!!!
ok everybody i need a little help its inspection time again and i have a few problems, my back up light do not work the keep blowing a 10 amp fuse that also goes to my cig lighter and my rear defroster, i can replace the fuse and about the third of forth time i hit reverse the fuse blows, also my singnal light are acting crazy when i trun them on the odomater dims when a singnal light comes on and then brightens back up when the signal light goes off, i have had it to the dealer and they have no clue, its a automatic by the way any ideas
Old Jan 8, 2008 | 09:11 AM
Kalevra's Avatar
Kalevra
Default RE: inspection time HELP!!!!!!
try a heavier fuse. 15 amp. if that blows then check the wiring where you can.
Old Jan 8, 2008 | 09:17 AM
lostcause's Avatar
lostcause
i have tried a 5 amp blew it right away to dont wanna go any heaver it could melt all kinds of stuff
Old Jan 8, 2008 | 09:53 AM
Kalevra's Avatar
Kalevra
check your wires then
Old Jan 8, 2008 | 10:55 AM
NHARINTON's Avatar
NHARINTON
5 amp......... i belive it should be a 15 or 20.... yeah cause a cig lighter and back up lamps is mor the 10...... my car is broken at home so i cant look for ya..... if you look on the fuse panel cover it will say the fuse location number and fuse size needed..... check that [/align]
Old Jan 8, 2008 | 11:03 AM
lostcause's Avatar
lostcause
o i ment i have tried a 15 amp sorry
Old Jan 8, 2008 | 11:19 AM
Kalevra's Avatar
Kalevra
try a 20 amp. it wont hurt anything, I think the cig lighter is a 15 amp anyway
Old Jan 8, 2008 | 11:49 AM
NHARINTON's Avatar
NHARINTON
yeah and in fact i called my wife and had her look in the car for me and i have a 25 in it.... never had a problem with reverse lights.....
on a side not the reverse, and blinkers are the onle electrical in the car that works!! stupid piece of ********** beep***beep***beep Neon..... oh its makin me mad!!
[/align]
