Where?
Old Jan 9, 2008 | 05:30 PM
SHACNEON7307's Avatar
SHACNEON7307
Default Where?
Where would I drill a hole to run the wires from my mobiledevices into the battery (power distribution)compartment? Or is there an already existing hole that I can use for these wires?
Old Jan 9, 2008 | 05:58 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: Where?
no drilling. run it to the fuse box on teh side, by the door. if you ever do need to get to the battery, just go through the rubber grommet by the drivers side feet
Old Jan 13, 2008 | 07:30 PM
SHACNEON7307
Default RE: Where?
How pray tell would I run the wire to the fuse panel on the inside? Where would I connect the wires?
And How would I run the wires through the grommet to under the hood, plus in that same subject which end do I run from ( outside going in or vice-versa)
Old Jan 13, 2008 | 08:01 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Where?
there is agromet is on the driver's side up under the dash a little. its easily accessible from under the hood, but a littl eof a reach up under the dash. i ran 4ga power wire through it on my se and 8ga wire through it on the SRT, so whatever you need to jam through it will fit.
Old Jan 13, 2008 | 08:09 PM
Dukk's Avatar
Dukk
Default RE: Where?
^ I agree - that's the best place for reasonable cable runs.
My ride was a little more unreasonable, two runs of 0ga...
Here's a firewall shot after the cable run but before it was loomed:
It was easier to drill it from the inside:
And a battery shot, for the curious (pre CAI install). Yeah it was dirty under there (how embarassing)
Old Jan 13, 2008 | 08:33 PM
SHACNEON7307
Default RE: Where?
where did you drill from the inside? For my purposes it would be better to drill a hole being that there are a "mess of wires" that need to go through... a 12-pin wire harness for aPA system(pictured belowplus 4 more (+) wires. (2 from the P.D.C. and 2 going to the alternating headlight flasher and the grille strobes)... and I do not think I'm going to be able to squeeze more than a dozen 10ga wires throught the grommet.
Here's a low quality video of my Neon (aka: "Flycar 7354" ) with her emergency response lights on.
http://www.youtube.com/watch?v=F435mzPR4T8
[IMG]local://upfiles/79556/EB3BA329F3B84E559FDF36B6489A2272.jpg[/IMG]
[IMG]local://upfiles/79556/6DB7C2ED95474457A29BEF4D3004F590.jpg[/IMG]
Old Jan 13, 2008 | 08:41 PM
flamingpinhead
Section Moderator
Default RE: Where?
alot of crap can fit through the gromet. but drill away if that seems the better option. up to you
Old Jan 14, 2008 | 12:22 AM
Dukk's Avatar
Dukk
Default RE: Where?
The holes are on the passenger side. Pull back the carpet and the firewall pad and you will see that same area that I drilled through.
