Security System?
Old Dec 6, 2004 | 08:11 PM
Ryan's Avatar
Ryan
Default Security System?
Hi I have a 2001 Neon SE and as far as I thought it really doesn't have any security features, however in the manual they talk about if it does it will protect the hood trunk, ect.. It also says when u set it you dash light will blink.. I figured I didn't have this because I don't have a blinking light in my dash.. However I noticed in my hood area I do have a pin switch with a wire hooked to it.. I've tried locking the doors where the horn beeps then opening my hood.. Nothing happens.. Is there a certain way to turn the alarm on or what?
Old Dec 6, 2004 | 08:24 PM
casper's Avatar
casper
Default RE: Security System?
there is, you have to goto the dealer and have them "turn it on" There is a thread on here somewhere, I will see if I can find it.
Old Dec 6, 2004 | 08:27 PM
casper's Avatar
casper
The name of the thread is "New neon alarm".
Thanks to Big Red Jim from srtforums.com for this one. Hopefully this might help some of you who either didn't know what to do or that you ever COULD do this. Apparently though, this will work on all 03+ Neon's with keyless entry. Just bring these instructions to your dealer and you're good ta' go
quote:
Connect DB3 to car located inside the car near hood release up and to right 3 inches. It is a white serial port.
Put DBR3 into to "Stand Alone 98-04"
Once in "stand alone 98-04" go to "security"
Once in "security" go to VTSS
Once in "VTSS" go to "misc"
Once in "misc" go to "configure"
Once there change "RKE" to "VTA"
After you are done the lock button will turn on the alarm showing a round red light on the instrument cluster above gas gauge for exactly 17 seconds after that the red light will go in to a slow blink.
_____________________________
Corey B.
Metallic Silver Dodge Neon SXT (2004)
Old Dec 6, 2004 | 08:38 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
You might want to call the dealer beforehand to see if they are going to charge you for this or do it for free. Some dealers are charging, some give you a freebie....best to check to avoid a surprise.....
Old Dec 6, 2004 | 10:51 PM
casper's Avatar
casper
Yeah, they should do it for free, but if they do charge try a different dealer or grab one of the service techs on lunch, throw hit a 10 or 20 and be done with it.
Old Dec 7, 2004 | 05:41 AM
TJW815's Avatar
TJW815
nothing like bribery to get the job done, I love it.....
U ever been tempted at work dusty?
Old Apr 21, 2012 | 01:52 PM
twalk1988's Avatar
twalk1988
MY security light is on and my 03 neon wont start...any suggestions
Old Apr 21, 2012 | 02:41 PM
darthroush's Avatar
darthroush
Section Moderator
You need the SKIM to be reprogrammed by a dealer or a shop with a DRBIII.
