pulseating prob continues
Old Dec 7, 2004 | 12:50 AM
dimst_oner2000's Avatar
dimst_oner2000
Default pulseating prob continues
my 01 plym neon has a pulsating shake at idle,i replaced the idle air control valve,didnt work is there any other common problems that neons have with pulsating engines?
Old Dec 7, 2004 | 01:13 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: pulseating prob continues
Try resetting the PCM. It could still be in limp mode because of the bad sensor.
Old Dec 7, 2004 | 04:11 AM
dimst_oner2000
whats the pcm? and how would i reset it?...and if this isnt the prob,would reseting it mess it up?
Old Dec 7, 2004 | 04:15 AM
Cr@zy Squ33
PCM = Power Control Module also known as the computer.
To reset it disconnect the negative battery cable for 30 minutes to an hour or more. That will reset it. And no, resetting it will not mess anythign up you'll be fine.
LowSlowNeon's Avatar
LowSlowNeon
The pcm is the neon's computer. Just disconnect your battery for a couple of hours and that will reset it. No, it won't hurt anything.
Old Dec 7, 2004 | 05:26 AM
TJW815's Avatar
TJW815
if you have an aftermarket alarm, keep your head away from the siren when reconnecting, TRUST ME it hurts, my ears were ringing for about 2 hours when I forgot
Old Dec 7, 2004 | 05:09 PM
casper's Avatar
casper
ORIGINAL: TJW815
Those alarms will get you every time, I think valet mode will fix that problem, but I could be wrong.
