Can anyone help
Old Jan 13, 2008 | 07:37 PM
emt23514's Avatar
emt23514
Default Can anyone help
I work fire and ems and am wanting to put a siren and mobile radio in my Neon however the neon isnt very friendly for this type of install does anyone have any suggestions or know of a site that I can get a mounting bracket for theses items? btw it is an automatic.
Old Jan 13, 2008 | 07:57 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Can anyone help
you could probably put a radio and such in, but you woul dhave to sacrifice the center console area. your right though, isnt really much of a place to mount one. under the dash would take up too much of what little leg room there is. perhaps on top of the dash might work as well?
Old Jan 13, 2008 | 08:14 PM
Dukk's Avatar
Dukk
Do you have the optional CD changer? If not, there is a pocket right above the cupholders that can be pulled and modified to hold a mobile radio.
For the siren, depending on size, there is a fair bit of room on the passenger side firewall (non-turbo) and also below the passenger headlight there should be enuf room - easiest to remove the headlight to gain access to that space.
Old Jan 13, 2008 | 08:36 PM
emt23514's Avatar
emt23514
hummmm think I may work something in the bottom part of the console I believe I can remote mount the radio so the bulk of it can be under the seat and the display can be dash mounted but not sure ill have to look at it and see
Old Jan 13, 2008 | 09:00 PM
emt23514's Avatar
emt23514
is there any one else who works fire or ems even volunteer that is in this forum
Old Jan 13, 2008 | 09:19 PM
flamingpinhead
Section Moderator
might try lookin around OT to find some ems/fire folks
Old Jan 14, 2008 | 06:48 AM
emt23514's Avatar
emt23514
OT?
Old Jan 14, 2008 | 08:50 AM
Undesolved's Avatar
Undesolved
Off Topic
