power inverter
Old Dec 9, 2004 | 01:59 AM
GroundControl's Avatar
GroundControl
Default power inverter
i hooked my power inverter into my ciggaret lighter and it worked fine. i had a switch put into where the cigertett ligher was so now there is no place to hook the inverter up to. i spliced the wires and ran it to the battery. when i flick the switch it works perfictley. When i flick the switch off it shuts off but is that gunna still be getting power and drain my battery at all. i doubt it will but i wana make sure.
Old Dec 9, 2004 | 02:02 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: power inverter
Nope. You should be good to go.
Old Dec 9, 2004 | 05:09 AM
casper's Avatar
casper
It will work perfectlly, unless it shorts out and starts a fire. You should have a fuse somewhere between the wire and the switch, as close to the battery as possible. That will make it safe.
Old Dec 10, 2004 | 02:34 AM
GroundControl
the only fuse that it has is on the inverter itself. there is none inbetween the inverter and the battery.
Old Dec 10, 2004 | 04:18 AM
TJW815's Avatar
TJW815
then my advice bryan, put an inline fuse on it. don't wanna burn ur car, well you may but insurance claims are a pain and teh don't always pay off good
Old Dec 11, 2004 | 11:22 PM
casper's Avatar
casper
Goto radio shack or your local car audio store, if you want something a litle "prettier", and buy an inline fuse holder and fuse, same or a little higher amperage than than the fuse in the inverter. Then cut the positive wire about 6-8 inches from the battery and put the fuse in. All done and not fire risk.
