need some quick help
Old Jan 19, 2008 | 01:09 PM
whtdoesitmatter's Avatar
whtdoesitmatter
Default need some quick help
a while ago neon r/t posted a quick list of all the parts needed to do the atx to mtx swap I have a whole donor car and just want to make sure i put the right parts into it and not leave any out? any1 find this list? if so i'll write up a how to after i swap it to end all questions on the subject...i promise lots of pictures also
Old Jan 19, 2008 | 02:15 PM
Undesolved's Avatar
Undesolved
Default RE: need some quick help
search is your best friend....
Old Jan 19, 2008 | 03:23 PM
03neonRT's Avatar
03neonRT
Right from my 2nd Gen Performance FAQ
Q: Can I swap in a manual transmission into my automatic Neon?
A: Yes, you can and will need the following: transmission (3.55 or 3.94), modular clutch, passenger side axle, clutch master and slave cylinder, shifter cables and clips, tranny side motor mount from a manual transmission 2nd gen, MTX PCM from your year car, shifter and shifter base, clutch and brake pedal assembly from a 2nd gen.
