brake question???
Old Jan 24, 2008 | 08:33 PM
moparfreak's Avatar
moparfreak
Default brake question???
is the rear brakes on the srt 4 the same as the r/t??? i know the front is different and i just bought a the fronts off ebay cause i want the big brake kit, but i want the rear to have a set of drilled and slotted as well but i found a kit for the srt 4 all the way around but didn't know if it would help???
thanks
Old Jan 24, 2008 | 09:18 PM
03neonRT's Avatar
03neonRT
Default RE: brake question???
Yes, the rear SRT-4 brakes are identical to the R/T rear brakes. The only "difference" is the SRT-4 uses a slightly thicker rotor OEM (for whatever reason they didnt put them on the R/T).
Old Jan 24, 2008 | 11:23 PM
moparfreak's Avatar
moparfreak
so then do i need to change the caliper as well?? for the thicker roators??? or will they fit the oems???
Old Jan 24, 2008 | 11:30 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Some brake info you may be interested in.
Also found that the rear rotors on 91-94 dodge cars (acclaim/spirit, lebaron, daytona, shadow/duster) are slighty thicker than neon rear rotors.
The rotor on the left is off a V6 spirit. Used a wire bruch on my drill to remove the rust, and slapped it on the car.
The lower rotor is the V6 rotor.
Using these on my 96 with 2G calipers and lines in the rear.
Old Jan 25, 2008 | 10:54 AM
03neonRT's Avatar
03neonRT
ORIGINAL: moparfreak
Nope, the R/T and SRT calipers are the same.
Old Jan 25, 2008 | 05:00 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
^^ really i never new that??? alright now when i change over my drums to disk in the rear will i have to change the mastercylinder and the porportaning valve??? or r they the same as well??? would like to do a conversion to rear disk but have to locate all the spindles calipers brackets ext.???? or is there anything else i will need to buy???
Old Jan 25, 2008 | 06:20 PM
Moparmatt440's Avatar
Moparmatt440
When I had my SXT and I put the rear SRT brakes I didnt change the master, you will just need to get the whole assembly from a SRT, the rear hub will cross over but you need the whole backing plate caliper mount from the SRT
Old Jan 25, 2008 | 11:25 PM
dtjackten's Avatar
dtjackten
thanks, were did u get urs from??? i was lookin on ebay and nothing.... maybe a junk yard, but the yards around me dont have srts in it, and same with the rts???
Old Jan 26, 2008 | 12:19 AM
moparfreak's Avatar
moparfreak
i know you want the rears but i just bought on set of srt's front for 175 both side
Old Jan 26, 2008 | 01:52 AM
moparfreak's Avatar
moparfreak
i just left ebay and there are a set of srt's rear, comes with caliper, rotors, and links basically evrything but the struts all the they did was just unbolts it off the strut and that is they are selling it
