Engine Mounts Gone Bad
Old Jan 26, 2008 | 09:40 AM
redskinz56's Avatar
redskinz56
Default Engine Mounts Gone Bad
When I got an oil change a few days ago....I was told that my engine mounts upper and lower have gone bad. What problems can this cause for my car and I was looking at a Dodge Neon Repair Manual and can't find anything listed under engine mount....is that the same thing as Upper and lower torque strut?
please help. I hear a clicking noise when my car is on....coming from the lower part of the hood of my car...by the tire.
Old Jan 26, 2008 | 11:09 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: Engine Mounts Gone Bad
well, to check the neon engine mounts is pritty easy, all u have to do is grab onto the coil pack area...or head and pull and push on the engine.... if the engine moves u have to get new mounts if not then they would be ok, alittle play is normal, but not alot of play.....
Old Jan 28, 2008 | 04:13 PM
redskinz56's Avatar
redskinz56
but as far as having a broken engine mounts what are the effects and how does it affect the drivabilty of neon?
is it supposed to shake the vehicle as you are stopping at a red light?
- when im stopping at a stop sign or red light, my car shakes unless i put it in neutral. seems as if the idling is affected.
make the gas pedal stiff?
make the engine noisier?
