not firing on 2 and 3 plug
Old Jan 26, 2008 | 06:16 PM
hollyneon's Avatar
hollyneon
Default not firing on 2 and 3 plug
i got a 2004 dodge neon it would start the other day had it jumped it started but was running rough its not firing on 2 and 3 cylinder will start but will blow fuse marked fp/asd thanks for any help
Old Jan 26, 2008 | 07:42 PM
contagious19's Avatar
contagious19
Default RE: not firing on 2 and 3 plug
ur plugs, or ur wires or it could b da coil. mine was da coil but it was misfire in cylinder 3
Old Jan 26, 2008 | 08:16 PM
hollyneon's Avatar
hollyneon
i had new plugs and core it cracked the first coil took it back and did the same thing to that one put the old one back still no firing on 2 and 3damn if iknow
Old Jan 26, 2008 | 11:01 PM
ewetho's Avatar
ewetho
2 and 3 share a coil. Time for plugs and wires. If it continues then get a coil.
If you have a DVOM (Multi-Meter) you can get the FSM out and check the coil ressistance and see if you can find if it is bad. May not show up till operating though so not definitive.
Old Jan 27, 2008 | 02:42 PM
spikeymikey87's Avatar
spikeymikey87
probably coil pack
Old Jan 27, 2008 | 06:11 PM
AnthemBassMan's Avatar
AnthemBassMan
-I'd say shoot for new plugs and wires first. My Mother-in-law's '92 Toyota Paseo was doing this very same thing then it wouldn't start at all. Similar setup with plugs too, down in the valve cover. Anyhow, I pulled the wires one at a timeand had her crank the engine to try to start it, and all four plug wires were arcing through the side of the boot. New plugs and wires and now the car is purring right along. My Mother-in-law said that it's now running better than it has in the past 4-6 months.
L8R,
Matt D.
