Door fuse.
Old Feb 1, 2008 | 07:34 PM
cougarcat13t's Avatar
cougarcat13t
Default Door fuse.
I have a 2000 Neon(base) and when I start it, the area where the mileage and so-on is, it flashes FUSE then Door three times, and the rest of the time I drive it, it says door above the mileage. I checked all my fuses and replaced the ones I found blown and it still does this. Also I had to take my dome light bulb out, because it constantly stays on. Anyone have any ideas?
Old Feb 1, 2008 | 08:41 PM
srtgtr34's Avatar
srtgtr34
Default RE: Door fuse.
+1
hey i got same problem, someone on here had a suggestion but i forgot it.
Does your battery constantly go dead too?
Old Feb 1, 2008 | 08:51 PM
cougarcat13t
No my battery does not go dead.
Old Feb 1, 2008 | 09:07 PM
srtgtr34's Avatar
srtgtr34
hmm, did your car come with the tac or did you buy a white faced gauge cluster?
Cause that came up after i got my gauge cluster.
Old Feb 2, 2008 | 04:05 PM
bone33's Avatar
bone33
remove the door light switch. its held on by one screw. just tape up the wire and shove it in the hole. i did this 3 years ago to my 2000 and its fine. the light wont come on when you open the door, but you can just turn it on munualy if you need it. the other door will still work as normal.
