Rough Idle & Crankshaft noise
Old Feb 2, 2008 | 05:55 PM
redskinz56's Avatar
redskinz56
Default Rough Idle & Crankshaft noise
Well my motor has been runing rough lately and my motor started a knocking sound coming from the crankshaft. I did have my timing belt changed right before I noticed this problem....perhaps the mechanic didn't know what he was doing?
How do I get this fixed?
Can i do it myself or get a mechanic to do it?
Txt 703.598.3031 or reply here thanks!
Old Feb 3, 2008 | 05:24 PM
bone33's Avatar
bone33
Default RE: Rough Idle & Crankshaft noise
before you do anything, take it back to the mechanic and have them look at it. if they want to charge you for diagnostics, threaten to throw a hissy fit infront of all the customers. you have to find out whats wrong, before you will know if you can DIY.
Old Feb 3, 2008 | 07:18 PM
Adionik's Avatar
Adionik
My idle has been **** lately too...I changed to V-power spark plugs & new wires...didn't make it any better
Old Feb 5, 2008 | 01:48 PM
redskinz56's Avatar
redskinz56
whats weird is that when i got an oil change they told me my engine mounts have gone bad as there was always a noise coming from the camshaft.
they never told me anything about the camshaft. once i changed the motor mount but it was still making the noise i did more reading about camshafts and does have a huge effect on the engine.
im shocked that they never noticed the camshaft because it is making a loud clicking noise. camshaft wobbles but ive been able to drive like this for months. i also changed the IAC and helped with the idle but still has rough idling.
should i replace the whole camshaft or just start with the basic first such as the bearing?
