2001 Neon Brake HELP!
Old Feb 11, 2008 | 11:50 PM
DodgeNeonProblem's Avatar
DodgeNeonProblem
Default 2001 Neon Brake HELP!
I am bamboozeled
2001 Neon, Left Rear Drum Brake problem.
The car in question had just recieved new Tires (just a bit overwidth)
Then it had some new rear brakes installed
Since then, the left rear, "at times" has "locked-up"
In an effort to fix the issue, I have done the following:
Swapped brake drums. OK for a while...
Turned the left rear brake drum. OK for a while...
Adjusted the brakes. OK for a while...
R & R'd the whole system. OK for a while...
The bearings are good and the E-Brake system is in working order.
The left rear cylinder has been replaced. All seems to be in good working order.
At first the problem only appeared while driving forward.
The quick fixwas to place it in reverse and it would release the brake...
Lately, it has only appeared while trying to drive in reverse.
And it does not "fix"it by driving forward.
I have done everything I know trying to fix this problem. Everyone I know seems to think they know how to fix the problem...
Please help me,
It is a moral imperative...
Thanks,
Gino
Old Feb 12, 2008 | 01:14 AM
Izero's Avatar
Izero
Default RE: 2001 Neon Brake HELP!
swap to discs and just save yourself the hassle...... thats my suggestion
Old Feb 12, 2008 | 04:46 PM
Undesolved's Avatar
Undesolved
how does one know if one has disc or drum brakes in the rear?
Old Feb 12, 2008 | 04:57 PM
bone33's Avatar
bone33
ORIGINAL: Undesolved
discs look like the front brakes on any car, just that they are in the rear. drums look like the rear brakes on your sxt.
Old Feb 12, 2008 | 10:44 PM
Undesolved's Avatar
Undesolved
so discs are just plain discs? would they have a caliper like the fronts?
Old Feb 13, 2008 | 04:40 PM
bone33's Avatar
bone33
yes but the rear disc caliper has an emergency brake function as well.
