HELP ME NEON WONT REVERSE!!!NEUTRAL TURNED 2 DRIVE
Old Feb 15, 2008 | 08:39 PM
ludlow08's Avatar
ludlow08
Default HELP ME NEON WONT REVERSE!!!NEUTRAL TURNED 2 DRIVE
K I HAVE A 00 NEON AND TODAY I CAME HOME AND PARKED IT ,WENT BACK TRIED TO REVERSE AND THE REVERSE WONT WORK AND NEUTRAL TURNED TO ANOTHER FORM OF DRIVE.ITS A 4 DOOR 2.0 LITER.I CHECKED THE TRANNY FLUID THE FLUID IS PINK AND DOESNT SMELL BURNED PLS HELP ANY INFO GREATLY APP.
Old Feb 15, 2008 | 08:42 PM
bone33's Avatar
bone33
Default RE: HELP ME NEON WONT REVERSE!!!NEUTRAL TURNED 2 DRIVE
Adjust gearshift cable as follows:
Place gearshift lever in the PARK (P) position.
Loosen shift cable adjustment screw.
Verify transaxle is in the PARK (P) position and the shifter lever is in gated PARK.
Tighten shift cable adjustment screw to 8 Nm (70 inch lbs.) torque.
Old Feb 17, 2008 | 11:44 AM
I own only Dodge's Avatar
I own only Dodge
Yea what he said!! your cable slipped somehow.
Old Feb 20, 2008 | 12:48 AM
master tech's Avatar
master tech
Site Moderator & Tech
Did you have a cable problem before this, and does it feel loose?
