Spark plugs soaked in oil
Old Feb 16, 2008 | 08:24 PM
kmaub's Avatar
kmaub
Default Spark plugs soaked in oil
Hi all. My daughter came home and told me her 200o Neon was stalling a lot. I told her it was about time she did a tune up. We took out the spark plugs and 2 of them were totaly and completly soaked in oil as if they were dipped in used oil. Can any one tell meif this is a total rebuild or is it a common thing with neons. I have never seen this withany car I have ever owned and thats about 15 cars.
Thanks for any help on this.
Old Feb 16, 2008 | 09:56 PM
03neonRT's Avatar
03neonRT
Default RE: Spark plugs soaked in oil
Should just be a simple replacement of the spark plug tube seals that are located inside the valve cover.
Old Feb 16, 2008 | 10:00 PM
l_pillon's Avatar
l_pillon
thats exactly what its gonna be..very common with neons... need new tube seals and it might be worth it to seal them with a sealant
Old Feb 17, 2008 | 01:16 AM
Izero's Avatar
Izero
change the valve cover gasket while you are at it too btw.....
Old Feb 17, 2008 | 08:31 AM
bone33's Avatar
bone33
dont worry about getting this fixed ASAP. i have been driving my 2000 with oil on the spark plugs since 2004. i swear im gonna fix it someday.
Old Feb 17, 2008 | 04:06 PM
12 volt's Avatar
12 volt
i would....unless you want to keep stalling andfouling up yourplug wires.
Old Feb 17, 2008 | 06:54 PM
kmaub's Avatar
kmaub
Thanks for the reply every one. It has put my daughter's mind at ease. I just thought it was a major problem because I have never seen a motor with this set up or I just never seen this in any 4 banger I have owed.
She has a date with the mechanic on Tuesday.
And again my thanks.
