how do i adjust the e brake answer by morning
on the back side of the drum theres that little rubber grommet that i need to take of to get at the adjusting screw
but what direction do i turn it, i am working on the car in the morning and would like to know by then thanks in advance
any pics? been down there so i may be able to tell ya if i knno exactly what ur talkin about, if its the little cap on the brake lines to bleed the brakes then just pull it
ORIGINAL: neonracer1010
http://forum.2gn.org/viewtopic.php?t...rum+adjustment
those are for disk brakes.. I'm not sure if it's the same. but mostlikely it is... same directions
ya the way i did was use a flathead screwdriver and insert it into a little whole in the drum....make sure it cranks downward and it should tighten it up...keep checking the e brake lever to check on the height u want it
