Yako / LED Help
hey yako i got the light kit in today, i have one problem though. My gas gauge won't light up all the way mine just uses the two middle ones and the right bottom on is very dim, yako was yours like that? Your rpm gauge by the higher rpm's. Mine looks like this http://www.importcarpartsplus.com/neon_notach_2k_2.jpg. Any help would be appreicated. But yako still waiting on the shorty.
use white bulbs on it, make sure theleds are lighting up, if not ur gonna have plug em the other way, see on the instructions somewhere in there says something about the 03 model and posibly the ones before, also on the back of the cluster only replace the bulbs that say ILLU or some like that wich of course stands for illumination take a pic of the back of the cluster and another one with the cluster on and the leds lighting up, if ur doing this during daylight grab a towel or something and put it over ur head and the cluster/steering wheel to see em light up
this is what mine looked like, i got 1white led on the gas gauge and the other 5 are blue, the other 2 blue were on the derectional turn signals, but i had to sand it like it says on the instructions to make it look better
okay i'll try the white one, my dad owned me last night. He came home and took over. I'll try that yako, one more thing yako and you e-mail or pm me the instructions to do the dome light (the big bulb i'm guessing) and the shifter lights.
check out this other thread
https://dodgeforum.com/m_1203287/tm.htm
the dome light.. justpop it off towards the passenger side with a flathead, the plastic cover should come off
yako the led's you gave me don't work with the dome, dash lights fixed though. I leave the dome stock
Trending Topics
the 9 led bulb is the one for the dome(
)on my car it was little bit loose try to twisted around a little, or does ur dome use a different kind of bulb? take some pics of all the work to see how it is comin along
