Intake manifold???
Old Mar 6, 2008 | 10:36 AM
underground6t9's Avatar
underground6t9
Default Intake manifold???
Does anyone know if the intake manifold from a 02 neon r/t will fit my 00 neon wich is soch? I want to know if its a direct bolt on or if I need to make some modifications.
Old Mar 6, 2008 | 10:45 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: Intake manifold???
u will have to hook up the baffles in them... so some wiring will be nessesy.. i went with a indy racing manifold....
Old Mar 6, 2008 | 12:08 PM
underground6t9
what do you mean by wiring? do you mena that I will need to moved some wires around to allow it to fit? But is the bolt patterbn the same? Do you know if I will need a intake manifold gasktet?
Old Mar 6, 2008 | 04:23 PM
dtjackten's Avatar
dtjackten
no there is a baffle type setup on the rt manifolds and u have to hardwire them into ur ecu.... not sure exactly how it works but that is why i went with my indy..... and indy was a good price
Old Mar 6, 2008 | 05:01 PM
contagious19's Avatar
contagious19
yea cus u got it from ilblackneon. its a direct bolt on but u need to connect those wires if u want the butterflies to work
Old Mar 6, 2008 | 08:18 PM
03neonRT's Avatar
03neonRT
ORIGINAL: underground6t9
The R/T Intake Manifold has dual runners and a set of butterflies that close off, or open up, the second set of runners at specified RPM's under wide open throttle. On the R/T, the butteflies are controlled by the PCM, but if you installed the manifold on a non-R/T Neon, then you would ahve to wire up the buttterflies with a RPM window switch and a few other things. Then you would set the butterflies to open (under WOT) from 0-3200 RPM and then from 4900-6750 RPM...
Old Mar 7, 2008 | 05:29 AM
lblackneon's Avatar
lblackneon
ORIGINAL: 03neonRT
^^^I didn't know it was that much of a pain.
Old Mar 7, 2008 | 02:10 PM
contagious19
ORIGINAL: lblackneon
ORIGINAL: 03neonRT
i think da r/t intake manifold is a hell of an upgrade, if only i had da money and knew where they sell one
Old Mar 7, 2008 | 02:36 PM
dtjackten's Avatar
dtjackten
^^ check mopar, and pay as much for one as the indy manifoldi am sure.....
Old Mar 7, 2008 | 05:53 PM
03neonRT's Avatar
03neonRT
ORIGINAL: dtjackten
The actual manifold is only like $250 if I remember right....the real money is spent on the butterflies, actuators, and motor (plus the other $100 for the RPM switch and what not). Thats why COMPLETE used R/T manifolds can still be sold for a nice chunk of change on forums. I'm not even sure you can still buy the above mentioned parts, but I remember seeing the actual R/T manifold on DodgeParts.com in the OEM section.
