Will these fit?
Old Mar 7, 2008 | 01:04 AM
SXT_P007's Avatar
SXT_P007
Default Will these fit?
I like these and i was wondering if 17x7 will 04 SXT.
Old Mar 7, 2008 | 01:45 AM
Yako's Avatar
Yako
Default RE: Will these fit?
the srt wheels are 17x6 the srt acr are 16x7.....
maight fit depending on what tires u use, and if not there are always spacers
Old Mar 7, 2008 | 12:08 PM
djmagic's Avatar
djmagic
should fit as long as you don't overdo the tires
Old Mar 7, 2008 | 01:39 PM
contagious19's Avatar
contagious19
mykazera rims are 17x7 wit 205/40 and they fit fine so they should fit depending on the offset
Old Mar 7, 2008 | 05:50 PM
03neonRT's Avatar
03neonRT
They'll fit as long as the offset is correct and they have a 5x100 bolt pattern...not to mention you need to wrap them in the correct size tire.
Old Mar 7, 2008 | 10:47 PM
SXT_P007's Avatar
SXT_P007
That's guys I'll get more info about them! And Yako I didn't mean to give you heat on the other forum i summited!
Old Sep 16, 2008 | 05:02 PM
mojamar's Avatar
mojamar
Question Need an expert opinion!
Will a bolt pattern of 5x114.3 fit on a 2004 neon?
If so, 205/55/15 tires fit?
Old Sep 16, 2008 | 05:37 PM
djmagic's Avatar
djmagic
no. Bolt pattern is 5x100. What is the standerd size on 15's anyways
Old Sep 16, 2008 | 08:03 PM
darthroush's Avatar
darthroush
Section Moderator
It doesn't matter what size the wheels are, there is only one bolt pattern that will fit.
Old Sep 17, 2008 | 09:15 AM
djmagic's Avatar
djmagic
size does matter somewhat, cant go bigger than 18 without modifications
