gauges
Old Mar 14, 2008 | 11:49 PM
lostcause's Avatar
lostcause
Default gauges
ok so i just put some gauges in my 02 neon, i put an air/fuel gauge in and the needle goes crazy when car is started, how do i fix that
Old Mar 14, 2008 | 11:50 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: gauges
its normal theres nothing to fix it
Old Mar 15, 2008 | 02:15 AM
Caraudioholic24's Avatar
Caraudioholic24
Default RE: gauges
a suggestion, I have a wide band autometer c2 in my 05. I had to get the entire kit with a wideband o2 sensor, then I had to drill a hole in my header and weld a bung on it to fit it. Works really well. A lot more accurate than regular cheap ones. But a bit more pricier and a lot more work. Factory o2 sensors will not cooperate with aftermarket a/f gauges. Been there.
Old Mar 15, 2008 | 02:44 AM
GrApHite03's Avatar
GrApHite03
Default RE: gauges
ya, it sounds as if you have whats called a "ricer light show"... narrow bands are useless.
Old Mar 15, 2008 | 12:22 PM
inthewerks's Avatar
inthewerks
Default RE: gauges
yeah. those a/f guages are crap. the lights going crazy when you first start the car up because the computer is using preset specs because the sensors cant get an accurate reading until the car is warmed up. doesnt matter anyways because the a/f sensor you have is non adjustable. get the aem wideband o2 sensor and guage kit
