Quick Question...
Old Mar 24, 2008 | 05:25 PM
whtdoesitmatter's Avatar
whtdoesitmatter
Default RE: Quick Question...
high temp silicone lol
Old Mar 24, 2008 | 05:52 PM
TN.Frank's Avatar
TN.Frank
From what I've heard our stock SOHC exhaust manis are total crap for flow. I think the header will help out some, maybe 2 or 3 hp. JMHO, YMMV.
Old Mar 26, 2008 | 09:41 PM
03neonRT's Avatar
03neonRT
If anything buy a used Magnum exhaust manifold, basically the best performance your going to get out of a short tube header...
Old Mar 26, 2008 | 09:45 PM
Mat00ES's Avatar
Mat00ES
If I could get my hands on one cheap I would.
Mat
Old Mar 27, 2008 | 03:19 AM
GrApHite03's Avatar
GrApHite03
its not gonna work without some fab... take a look at the cat flange.
Old Mar 27, 2008 | 02:03 PM
eaks's Avatar
eaks
Hey guys.. i bought an R/T header last year in addition to the Exhaust.. is it worth while to throw it on? 2001 neon.. full srt4 exhaust and should i throw the header on or am i looking at too much work for too little gain?
And how hard are they to install? does the engine need to be moved or anything? Can i just unblot the old one and throw in the R/T (magnum?:S) header?
Thanks
Old Mar 27, 2008 | 08:35 PM
GrApHite03's Avatar
GrApHite03
I tried to use the MLS magnum gasket when i put one on my non-mag and it leaked. I bought a non-mag gasket and port matched it and it was fine after that. used a dremel with a rough sanding bit.
As far installing it... Disconnect the Cat and move the exhaust out of the way. Heat shield is a bitch, didn't even put it back on. All bolts can be reached from underneath or above. I suggest removing and installing the manifold from under the car. You may be able to get it out from above, but i was even going to try.
k3v
