Coolant flush
Old Mar 27, 2008 | 04:38 PM
ricerchik02's Avatar
ricerchik02
Default Coolant flush
I'm gonna be doing a flush pretty soon here (warmer weather comin, finally!!!). How much of that 50/50 antifreeze will I need to fill it back up? Two bottles? More or less?
Old Mar 27, 2008 | 05:27 PM
03neonRT's Avatar
03neonRT
Default RE: Coolant flush
The cooling system takes 6.5 quarts of coolant, so a bit over 1.5 gallons...so if your getting the pre-dilluted stuff, you'll need two bottles with some left over at the end.
Old Mar 27, 2008 | 06:05 PM
djmagic's Avatar
djmagic
how often should you do that. Just curious, i think i only have like at most 15k on my coolant..
Old Mar 27, 2008 | 06:07 PM
03neonRT's Avatar
03neonRT
Its usually every 5 years or 100,000 miles, but I've done mine every third oil change (~15,000-20,000 miles) since I got the car.
Old Mar 27, 2008 | 06:36 PM
Adionik's Avatar
Adionik
whatever star...you know you're not flushing it...
Old Mar 27, 2008 | 10:40 PM
djmagic's Avatar
djmagic
but you live where its very cold, should i do that too, AZ lots of heat?
Old Mar 28, 2008 | 12:35 AM
Kalevra's Avatar
Kalevra
DO A COOLANT FLUSH AT LEAST 1-2/YEAR
our radiators are aluminum and coolant corrodes aluminum. if you dont do it often, it will wear right through the barrier between your engine coolant and Trans fluid.... which is not a pretty thing to happen. trust me... my wallet will be hurting for awhile...
Old Mar 28, 2008 | 12:40 AM
djmagic's Avatar
djmagic
well i'll get it done within the next few oil changes. Gotta figue out the stalling problem first. Hopefully it doesn't happen again then no problem.
Old Mar 28, 2008 | 09:51 AM
ricerchik02
ORIGINAL: Adionik
Thats right, cuz you'll be doing it for me
Cool, thanks03neonRT
Old Mar 30, 2008 | 07:35 PM
inthewerks's Avatar
inthewerks
come on, there is a reason why our coolant costs almost 20 bucks a gallon. there is a special additive for non corrosion that lets it go for 100,000 miles before it needs to be changed. im gonna wait till my car hits close to 100k before i do mine. unless you overheated or blew a hose or something.
